The Samsung Spinpoint M9T mobile SATA drive delivers high capacity in a thin design to give customers the ideal solution for external and mobile applications. The 2.5-inch drive is just 9.5mm thin and available in capacities of 1.5TB and 2TB.
- Max. 667GB formatted capacity per disk
- SATA Native Command Queuing feature
- TuMR/PMR head with FOD technology
- SATA 6Gb/s interface support
- Load/unload head technology
- ATA Security Mode feature set
- ATA S.M.A.R.T. feature set
- SilentSeek™
- NoiseGuard™
- Interface: SATA 6Gb/s (3Gb/s, 1.5Gb/s)
- Rotational Speed: 5400-RPM class
- Cache: 32MB
- Average Seek Time (typical): 12ms
- Average Latency: 5.6ms
- Drive Ready Time (typical)2: 3.5ms
- Media to/from Buffer (max): 169MB/s
- Buffer to/from Host (max): 600MB/s
- Nonrecoverable Read Error: 1 sector in 10E14 bits
- Controlled Ramp Load/Unload: >600,000
- Idle: 2.5 bels
- Performance Seek: 2.7 bels
- Voltage: +5V ± 5%
- Spin-up Current (max): 1000 mA
- Read/Write (avg)3: 2.3W
- Low Power Idle (avg): 0.7W
- Standby (avg): 0.18W
- Sleep (avg): 0.18W
- Height: 9.5mm ±0.2mm (0.374in ±0.008in)
- Width: 69.85mm ±0.25mm (2.75in ±0.010in)
- Length: 100.35mm +0.2/-0.25mm (3.951mm +0.008/-0.010in)
- Weight (max): 130g (0.29lb)
