Your gaming world will be more lifelike than ever before. Packing in 1.7 times the pixel density of Full HD, QHD resolution boasts incredibly detailed, pin-sharp images. Experience a fuller view with more space to take in all the action.
Reveal the whole picture. DisplayHDR 600 delivers more contrast, with deeper blacks and brighter whites to help you uncover enemies or secrets lurking in the shadows. Even in dark scenes, every detail shines with clarity.
Speed through scenes. 240 Hz refresh rate eliminates lag for exhilarating gameplay with ultra-smooth action. Jump on enemies right when you see them with a 1 ms response time and blur-free frames.
Effortlessly smooth game play. AMD FreeSync Premium Pro features adaptive sync technology which reduces screen tearing, stutter, and input latency. Low frame rate compensation ensures every scene flows seamlessly.
Vivid scenes wrap even more tightly around you. Experience the next level of heart-pounding gaming that's superior to anything you've seen before. The 1000 R display fills your peripheral vision and draws you into the character's shoes.
Reach the height of success. Swivel, tilt, and adjust the monitor position until you're set up for victory. Fully compatible with VESA-standard monitor arms, the screen can be moved effortlessly to your ideal staging.
Find more with an extended view. Discover hidden gems or flank enemies in full stealth with the ultrawide 21:9 aspect ratio. Extra context in every match brings you closer to the top of the leaderboard.
With core lighting, add personality to your setup with multiple color modes that leap off the screen and into your reality. Gaming escapes beyond the screen with ambient CoreSync technology that matches your game's on-screen colors for world-blending immersion.
Power on for instant action. With Auto Source Switch+, your monitor detects when connected devices are turned on and instantly switches to the new source signal. This helps you get to your game play faster without flipping through multiple input sources.
- Samsung Odyssey G6 S27BG650EU - G65B Series - LED monitor - curved - QHD - 27" - HDR
- LED-backlit LCD monitor - 27" - Smart monitor
- Energy Class
- Class F
- Energy Consumption per Year
- 38 kWh
- Curved Screen
- Adaptive-Sync Technology
- AMD FreeSync Premium Pro
- Wi-Fi, USB 3.0 hub, Bluetooth 5.2 adapter
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- QHD 2560 x 1440 at 240 Hz
- Brightness
- 350 cd/m²
- Contrast Ratio
- 2500:1
- HDR Capable
- DisplayHDR 600
- Response Time
- 1 ms (grey-to-grey)
- Gaming
- Colour Support
- 1 billion colours
- Colour Gamut
- 95% DCI
- Input Connectors
- 2xHDMI, DisplayPort
- Built-in Ethernet
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 100-240 V
- Black
- 61.58 cm x 31.11 cm x 57.83 cm
- 6.4 kg
- CEC, HDCP 2.2
- Display Type
- LED-backlit LCD monitor / TFT active matrix - Smart monitor
- Energy Class
- Class F
- Energy Class (HDR)
- Class G
- 38 kWh
- Diagonal Size
- 27"
- Curved Screen
- Yes (1000R)
- Operating System
- Tizen
- Built-in Devices
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 350 cd/m²
- Contrast Ratio
- 2500:1
- HDR Certification
- DisplayHDR 600
- Colour Support
- 1 billion colours
- Colour Gamut
- 95% DCI
- Response Time
- Gaming
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Game mode, ConnectShare, Flicker Free technology, Image Size, Eye Saver Mode, Factory Tunning, Factory Calibration Report, Movie Mode, DLNA, Quantum Dot Technology, Graphics Mode, Auto Source Switch+, Adaptive Picture, Ultrawide Game View, Tap View, Sound Mirroring, CoreSync lighting design, Adaptive Sound, Game Bar 2.0, far-field voice interaction, Virtual AIM Point, Mobile to Screen Mirroring, Gaming Hub, Workspace, Samsung TV Plus, Colour Mode, Entertain Mode
- Black
- 61.58 cm x 31.11 cm x 57.83 cm - with stand
- 6.4 kg
Audio
- Speakers
- 2 x HDMI (HDCP 2.2) , DisplayPort 1.4 , Headphones , 2 x USB 3.0 , LAN (RJ-45)
Mechanical
- Tilt Angle
- -9/+13
- Swivel Angle
- 30
- Rotation Angle
- -92/+92
- Height Adjustment
- 120 mm
- VESA Mounting Interface
- 100 x 100 mm
- Included Accessories
- Remote control
- Cables Included
- 1 x DisplayPort cable
- CEC, HDCP 2.2
- Security Slot Type
- Kensington security slot
- Input Voltage
- AC 100-240 V
- Power Consumption SDR (On mode)
- 26 kWh/1000h
- Power Consumption HDR (On mode)
- 61 kWh/1000h
- Power Consumption (Typical)
- 26 Watt
- Included Software
- Intel Wireless Display, Microsoft 365, SmartThings, Google Duo, Bixby Voice Assistant
- Dimensions & Weight Details
- With stand - width: 61.6 cm - depth: 31.1 cm - height: 57.83 cm - weight: 6.4 kg , Without stand - width: 61.58 cm - depth: 16.56 cm - height: 38.44 cm - weight: 4.5 kg
- Shipping Width
- 68.8 cm
- Shipping Depth
- 21.4 cm
- Shipping Height
- 46.1 cm
- Shipping Weight
- 8.8 kg
- 10 °C
- 40 °C
- 10 - 80% (non-condensing)
