The Samsung T7 Shield is built to withstand the challenges of daily use with its shock-resistant feature, ensuring your data stays safe even when on the move.
High-speed transfers
Experience fast data transfers with the Samsung T7 Shield, boasting an interface speed of 10.0 Gbps (USB 3.2 Gen 2) and a maximum data transfer rate of 1050 MB/s, making file sharing quick and efficient.
Secure storage
With 256-bit AES hardware encryption, the Samsung T7 Shield offers strong security for your data, giving you peace of mind that your files are protected against unauthorized access.
Samsung T7 Shield MU-PE1T0R - SSD - 1 TB - USB 3.2 Gen 2
Solid state drive - external (portable)
1 TB
Hardware Encryption
Encryption Algorithm
256-bit AES
USB 3.2 Gen 2 - USB-C
Data Transfer Rate
10.0 Gbps (USB 3.2 Gen2)
Shock resistant
Power Source
USB bus
Enclosure Colour
Blue
88.15 mm x 13 mm x 59 mm
98.5 g
3-year warranty
1 TB
Hardware Encryption
256-bit AES
USB 3.2 Gen 2
Shock resistant
88.15 mm
13 mm
59 mm
98.5 g
Performance
Interface Transfer Rate
Max Data Transfer Rate
1050 MB/s
Expansion & Connectivity
1 x USB 3.2 Gen 2 - 24 pin USB-C
Power Source
USB bus
Microsoft Windows 7 or later, Android 5.0 or later, Apple MacOS X 10.10 or later
