Samsung unveiled high-performance, high-density SSDs that offer over large memory storage. Among the highlights were the 840 EVO, a consumer-oriented entry-level, high-performance SATA based SSD.
The Samsung SSD 840 EVO line-up makes use of the industry's most compact 10-nanometer class high-performance NAND flash memory, which Samsung began mass producing in April. With these chips and Samsung's proprietary multi-core controller, the Samsung SSD 840 EVO achieves unrivaled value for performance with improved sequential read and write speeds.
Samsung has released the entry-level SSD '840 EVO' line-up with significantly higher sequential write performance. Utilizing the industry's most compact 10 nm-class 128 Gb high-performance NAND, Samsung proprietary controller and turbo write drive, the Samsung SSD 840 EVO boasts superior performance. The Samsung SSD 840 EVO also has flexible product supply capacity, making it the most competitive device on the market today.
