The Samsung M3 Portable External Hard Drive delivers handy portable storage. It is easy to take wherever you go, and has ample capacity of 1.5TB. The durable black design stands up to the rigors of daily use.
- Handy portable storage
- Durable black design
- SafetyKey protection for your data
Contents
- M3 Portable External Hard Drive
- USB cable
- Quick Install Guide
- Software preloaded on the drive
- Electronic User Documentation (PDF)
- Windows 7/Vista/XP, Mac OS X 10.4.8 or later
- SuperSpeed USB 3.0 (Max): 4.8Gb/s
- Temperature (operating): 5° to 40°C (41° to 104°F)
- Temperature (nonoperating): -20° to 65°C (-4° to 149°F)
- Weight (Max): 169g (1.5TB)
- Height (Max): 17.5mm max
- Width: 82mm
- Length: 112mm
- 3-year limited warranty
Software
- AutoBackup personal backup solution
- Secure Manager for worry-free data security
- SecretZoneTM can encrypt data on the device
