Easy to use desktop accounting for small businesses
Sage 50c Standard seamlessly combines the power and productivity of a trusted desktop solution, with secure online access and Microsoft Office 365 integration.
Run your business more efficiently with an easy to use, time-saving, solution to manage your accounting, invoicing, cash-flow, inventory, taxes, stock and so much more.
Sage 50c connected with Microsoft Office 365 Business Premium
With Sage 50c Standard, you get all you need for best in class productivity. From surfacing Sage 50c data in Outlook, to powerful financial reporting in Excel - Office 365 seamlessly integrates to enable you to run your business wherever you are.
In order to help you make the most of your Sage 50c package, there is a 1 year, 1 user subscription to Microsoft Office 365 Business Premium included for free with your purchase of Sage 50c Standard. With Sage 50c you get all you need for best in class productivity.
Setting the Standard in accounting software
Manage up to 10 companies with Sage 50c Standard. Quickly and easily manage your stock, and manage multiple departments and budgets.
With regular product updates, and award winning telephone, and online support included, Sage 50c offers you a comprehensive accounting solution to manage your business with.
Easy to use, comprehensive accounting for your business
As any small business owner or adviser will tell you, cash is king.
With Sage 50c you can quickly and easily manage cash-flow, income, expenses, payments & VAT - leaving you free to get on with what you're passionate about.
Add power and productivity to your business with Sage 50c Standard. Easily create professional invoices and quotes, connect to your bank account, and assess your business performance with powerful reporting and dashboards.
With Sage 50c, you're in control.
Comprehensive stock management
Knowing how much stock you have is vital for fulfilling orders and showing an accurate stock value on your management reports.
With Sage 50c Standard, the stock take option makes it easy to adjust your stock levels when doing a stock take.
Stock valuation is also simple to calculate - important when producing accurate accounts at the end of each accounting period.
Finally, with Sage 50c Standard it's simple to open and close stock journals and to create profit analysis reports.
Secure cloud data access and storage
Whether you want to work in real time with your accountant or simply access your data, you can now work anywhere, anytime.
Thanks to Sage Drive you can access everything in the office or on the go, via mobile, desktop or web browser.
Sage 50c also backs up automatically to the cloud - giving you peace of mind, that your business is covered whatever happens.
Go mobile and paperless with 50c
Thanks to Sage 50c's smart mobile apps you can invoice or record your expenditure wherever you are.
By utilising the Microsoft Office 365 integration, you can photograph your expenses, invoices or any other paperwork with Sage Capture. Then, save them to One Drive and post the transaction on Sage 50c. No more paperwork required - just your mobile or tablet.
Minimum System Requirements
- IBM compatible computer with a 2GHz processor or higher
- 2GB RAM (GB for PCs running a 64-bit operating system)
- 5GB free disk space
- Screen resolution of 1024x768
- Network Users only: 1Gbps network (100 Mbps minimum).
- Internet connection with minimum download speed of 4Mbps and download speed of 2Mbps
- Internet Explorer 10 or later is required.
Supported Operating Systems
- All 32 or 64-bit variants of Microsoft Windows 10, Windows 8, Windows 7, Windows Vista, Windows Server 2008 or Windows Server 2012
- Works with Microsoft Office 2016, 2013 and 2010 (32-bit editions) or 2007 and 2003.
- Microsoft.NET Framework 4.5
