The Ruckus ZoneFlex 7352 delivers high-performance and reliable 802.11n
wireless networking at the industry's most affordable price point. Unlike
any other 802.11n wireless solution in its class, the ZoneFlex 7352 combines
patented adaptive antenna technology and automatic interference mitigation
to deliver consistent, predictable performance at extended ranges with up to
an additional 4dB of BeamFlex gain on top of the physical antenna gain and
up to 10dB of interference mitigation.
Additional performance enhancements to signal gain can be attributed to the
chip-based transmit beamforming capability adding 3 dB when associated to a
compatible client. The 7352 is also ideal for client performance with mobile
devices that constantly change orientation with dual-polarized antennas that
adapt to hand-held device movement.
Each ZoneFlex 7352 integrates Ruckus-patented BeamFlex, a softwarecontrolled,
high gain antenna array that continually forms and directs each 802.11n
packet over the best performing signal path. The ZoneFlex 7352 automatically
selects channels for highest throughput potential using Ruckus ChannelFly
dynamic channel management, adapting to environmental changes. Once
deployed, enterprises never have to worry about constant site surveys as the
environment changes.
A sleek and low-profile design, the ZoneFlex 7352 was purpose-built for
cost-minded enterprises requiring reliable high speed client connectivity.
It is ideal for a variety of enterprise and hotspot environments including
hotels, schools, retail outlets, branch offices and public venues.
The ZoneFlex 7352 can be deployed as a standalone access point or as part of
the centrally-controlled Smart Wireless LAN with the Ruckus ZoneDirector.
The ZoneFlex 7352 can also be easily deployed using Smart Mesh Networking to
extend Wi-Fi services in locations where Ethernet cabling is not available
or cost prohibitive.
Patented BeamFlexâ„¢ Technology Extends Signal Range, Improves Stability of
Client Connections All ZoneFlex 7352 Smart Wi-Fi access points integrate a
software-controlled smart antenna array that delivers up to an additional
4dB of BeamFlex gain and 10dB of interference mitigation. This allows a 2 to
4x improvement in signal range and a reduction in packet loss from the
ability to automatically mitigate interference and avoid obstacles.
Advanced WLAN Applications with Smart/OSAdvanced WLAN Applications with
Smart/OS When used with the Ruckus ZoneDirector Smart WLAN controller,
each ZoneFlex 7352 supports a wide range of value-added applications such as
guest networking, Smart Wireless Meshing, Dynamic PSK, hotspot
authentication, wireless intrusion detection and many more. With Smart/OS,
WLANs can be created and mapped to the same or different APs or VLANs. In a
centrally managed configuration, the ZoneFlex 7352 works with a wide range
of authentication servers including Microsoft's Active Directory, LDAP, and
RADIUS.
Flexible Deployment Options
ZoneFlex 7352 APs can be deployed as a standalone AP or as part of a
centrally managed wireless LAN using ZoneDirector Smart WLAN controllers.
ZoneFlex 7352 can be deployed across any L2/L3 network and can bridge
traffic onto the local network, tunnel to a central location using L2TP or
PPPoE, or route between the WAN and NAT'ed private subnets. It can be wired
to the network or connect wirelessly by meshing to another AP when Ethernet
cabling is unavailable. When used with the ZoneDirector, each ZoneFlex 7352
is automatically configured through the network making deployment quick and
easy.
Complete Local and Remote Management
Each ZoneFlex 7352 can be managed as a standalone AP through a Web-based
GUI, using SNMP or through the Ruckus FlexMaster Wi-Fi remote management
system. Local management can also be performed using the ZoneDirector Smart
WLAN controller. FlexMaster is a LINUX-based software platform that uses
industry-standard protocols to perform bulk configuration, fault detection,
monitoring and a wide range of troubleshooting capabilities over a wire area
connection. The ZoneDirector enables local management and control of APs,
adding value-added services such as transmit power control, guest networking
and meshing.
