One of the first concurrent, dual-band (2.4/5Ghz) outdoor 802.11n access point, the ZoneFlex 7762 is in a class by itself. Ideal for enterprises looking to extend their wireless network outdoors or service providers that want to build multimedia hotspots and offload bulky data traffic from 3G networks, the ZoneFlex 7762 delivers one of the industry's highest performance at range.
The ZoneFlex 7762 uniquely combines adaptive antenna technology, adaptive meshing and the power of 802.11n to enable a new level of outdoor performance at the lowest cost. Built to withstand the harshest of outdoor conditions, Ruckus designed the ZoneFlex 7762 with the flexibility to function as a standalone AP or as a managed device, using the same wireless controller as its indoor Smart Wi-Fi products. If no Ethernet cabling is available, the outdoor AP meshes seamlessly with the indoor ZoneFlex 7962. Unprecedented performance enables connections of 150Mbps or more between mesh nodes at distances of up to 300 meter or more. In addition, unlike other outdoor Wi-Fi device today, the ZoneFlex 7762 provides advanced interference mitigation to ensure the highest resilience for both client and inter-node mesh connections. Now customers have a simple to use, deploy - indoor/outdoor - Smart Wi-Fi environment that provides extended range, simple deployment, reliable connectivity and consistent performance at range. Now THAT'S interesting.
