            Small Solar Panel helps charge any Ring USB-C Security Camera—or barrel plug Security Camera with the included USB-C to barrel plug adapter. Plus, its compact design makes it oh-so-easy to place or reposition. Mount horizontally, then use the adjustable arm with 180 degrees of tilt to get the perfect angle to maximise your solar power.
- For best performance, Ring recommends at least 2-3 hours of direct sunlight per day.
