BLE remote control suitable for the RICOH THETA series. A BLE remote controller that can be easily connected and can easily release the shutter remotely without connecting to a smartphone wirelessly.
Bluetooth Low Energy power saving design. Battery life is 100 days (when the power is turned on for 8 hours a day and the shooting signal is transmitted 50 times).
Thin size with a thickness of 12 mm.
Pairing state with THETA can be maintained for 8 hours in a row, there is no need to reconnect.
Reliable weather resistant construction
[Compatible models] RICOH THETA SC2, RICOH THETA Z1, RICOH THETA V (as of September 2020)
Made of aluminium, which is lightweight yet has excellent stability. High-quality emboss processing.
An attachment for the THETA selfie stick (TM-2 / TM-3) is included.
Ricoh TR-1 camcorder remote control
Camcorder remote control
1.2 cm
Supported Devices
Camcorder
Wireless Technology
Bluetooth
CR2032
Ricoh THETA SC2, THETA V, THETA X (2023), THETA Z1
1.2 cm
Wireless Technology
Bluetooth
Supported Devices
Camcorder
Splashproof
Attachment for selfie stick
CR2032
