With the printers you benefit from the same expertise. The space-saving Aficio SP C240DN is the neat solution to those wanting affordable hardware functions and market-leading image quality.
Ricoh SP C240DN - printer - colour - laser
Printer Type
Workgroup printer - laser - colour
23.8 kg
Media Size Class
A4
Max Media Size
A4 (210 x 297 mm)
Max Media Size (Custom)
210 mm x 297 mm
Print Speed
Up to 16 ppm - colour - A4 (210 x 297 mm) , Up to 16 ppm - B/W - A4 (210 x 297 mm)
Max Resolution (B&W)
2400 x 600 dpi
Max Resolution (Colour)
2400 x 600 dpi
Automatic Duplexing
USB, LAN, USB host
220 MHz
RAM Installed (Max)
64 MB
Language Simulation
Windows GDI driver
Media Type
Envelopes, plain paper, cards, bond paper, recycled paper, thick paper, thin paper, middle thick paper
Total Media Capacity
250 sheets
Media Handling
250-sheet input tray, 1-sheet multipurpose tray
Monthly Duty Cycle (max)
30000 pages
Print server - Ethernet, Fast Ethernet
Microsoft Windows Server 2003, Apple MacOS X 10.3 or later, Microsoft Windows Vista / XP / 7, Microsoft Windows Server 2008
40 cm x 45 cm x 32 cm
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD
Wired
USB, LAN, USB host
2400 x 600 dpi
2400 x 600 dpi
Direct Printing Specifications
PictBridge
Automatic Duplexing
First Print Out Time B/W
14 sec
First Print Out Time Colour
14 sec
Language Simulation
Windows GDI driver
Media Handling
220 MHz
RAM
RAM Installed (Max)
64 MB
Media Handling
Media Type
Media Size Class
A4
Max Media Size
A4 (210 x 297 mm)
210 mm x 297 mm
Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm)
Media Weight
60 g/m² - 160 g/m²
250 sheets
Media Feeders
1 x automatic - 250 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 160 g/m² , 1 x manual - 1 sheet - A4 (210 x 297 mm) weight: 60 g/m² - 160 g/m²
Max Media Capacity
750 sheets
Output Trays Capacity
150 sheets
Duty Cycle
30000 pages
Print server
Network / Transport Protocol
TCP/IP, Bonjour
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Consumables Included
1 x toner cartridge (black) - up to 1000 pages , 1 x toner cartridge (yellow) - up to 1000 pages , 1 x toner cartridge (magenta) - up to 1000 pages , 1 x toner cartridge (cyan) - up to 1000 pages
Power supply - internal
Frequency Required
50/60 Hz
1.3 kW
Power Consumption Stand by / Sleep
10 Watt
