Small, smart and energy-efficient, the SP 311SFNw is designed to impress. Compact enough to fit unobtrusively on a desk, this B/W A4 laser MFP will astound you with its speed and efficiency. The device is easy to operate and simple to maintain. Its energy consumption is very low. And it incorporates a host of environmentally responsible features such as energy saver mode and automatic duplex to lower your carbon footprint. In short, if you're looking for fast, compact, energy-efficient B/W MFP, you'll find it in the SP 311SFNw.
