The SP 211 is an affordable monochrome laser printer with a 150 sheet standard paper capacity from an embedded tray. High speed USB 2.0 connectivity makes the SP 211 suitable as a personal printer.
Ricoh SP 211 - printer - B/W - laser
Printer Type
Personal printer - laser - B/W
7.2 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
100 mm x 148 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 22 ppm - max speed
Max Resolution (B&W)
1200 x 600 dpi
USB 2.0
RAM Installed (Max)
128 MB
Language Simulation
Windows GDI driver
Media Type
Plain paper, recycled paper
Total Media Capacity
150 sheets
Media Handling
150-sheet input tray, 1-sheet multipurpose tray
Monthly Duty Cycle (max)
20000 pages
Recommended Monthly Volume
400 pages
Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2003 R2, Microsoft Windows Server 2008, Windows 8, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Windows 8.1
Microsoft Certification
Compatible with Windows 7
40.2 cm x 36 cm x 16.5 cm
Printer Type
Personal printer - laser - monochrome
Printer
Print Speed
Wired
USB 2.0
1200 x 600 dpi
First Print Out Time B/W
10 sec
Language Simulation
Windows GDI driver
Media Handling
RAM
RAM Installed (Max)
128 MB
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
100 mm x 148 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 148 mm, B6 (125 x 176 mm)
Media Weight
60 g/m² - 105 g/m²
150 sheets
Media Feeders
1 x automatic - 150 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m² , 1 x manual - 1 sheet - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m²
Output Trays Capacity
50 sheets
Duty Cycle
20000 pages
400 pages
1 x USB 2.0 - 4 pin USB Type B
Consumables Included
1 x toner cartridge - up to 700 pages ISO/IEC 19752
Power supply - internal
Frequency Required
50/60 Hz
400 Watt
Power Consumption Stand by
65 Watt
Power Consumption Sleep
5 Watt
