            Seize the unfair advantage with both hands with the Razer Wolverine V2 Pro - a high-performance wireless controller officially licensed by PlayStation. Armed with Razer HyperSpeed Wireless and a loadout of advanced features for top-tier competitive play, the time has come to claim your rule on PS5 and PC.
Razer HyperSpeed Wireless for low-latency, gaming grade performance. Delivering an ultra-fast 2.4GHz wireless connection via its included USB-A dongle, the controller ensures seamless performance that meets the demands of competitive gaming on PS5 consoles and PC. Razer Mecha-Tactile Action Buttons for ultra-fast actuation with tactile feedback. With a shorter actuation distance for quicker button presses and improved tactility to feel every input, the controller brings a whole new level of speed and consistency to your game. 8-Way Microswitch D-Pad for articulate and precise control in fighting games.
Feel and hear every single directional press as microswitches are engaged, enabling accurate and intentional moves when doing intricate combos. Razer HyperTrigger for quickfire execution in FPS games. Always be first to fire with triggers that can switch from measured, full-range pulls to lightning-quick clicks that feel like the actuation in our fastest gaming mice. 6 Remappable Buttons and Interchangeable Thumbsticks for customized layouts and control. Map its 4 extra triggers and 2 custom bumpers to your preferred commands, and further tailor the controller to your playstyle with 2 additional thumbstick caps. Powered by Razer Chroma RGB for greater personalization.
- "Razer™ HyperSpeed Wireless for low-latency, gaming grade performance"
- "Razer™ Mecha-Tactile Action Buttons for ultra-fast actuation with tactile feedback"
- "8-Way Microswitch D-Pad for articulate and precise control in fighting games"
- "Razer™ HyperTrigger for quickfire execution in FPS games "
- "6 Remappable Buttons and Interchangeable Thumbsticks for customized layouts and control "
- "Powered by Razer Chroma™ RGB for greater personalization "
- Height: 65 MM
- Width: 106 MM
- Depth: 162 MM
Manufacturer Warranty - 1 Year
