With the Razer Sphex, Razer introduces the first gaming grade desktop skin. With a value proposition unmatched by other gaming mouse mats, the Razer Sphex delivers high tracking quality on the thinnest mousing surface ever. Additionally the multiuse adhesive of the Razer Sphex lets you attach and remove it on any surface, allowing you to take it with you wherever you go.
High performance for Optical and Laser mice
The Razer Sphex was made with one primary mission in mind: to make high gaming grade performance affordable for everyone. And the results speak for themselves. The Razer Sphex keeps up with any other mousing surface regarding precision and tracking quality for both Optical and Laser mice.
Adheres to any surface
The innovative adhesive used for the Razer Sphex enables you to attach and remove it easily; making it the perfect companion anywhere you go. And don't worry about it getting dirty, as you can just wash it and it's going to be like new again.
Gaming grade desktop skin
The Razer Sphex brings a new approach to the gaming surface line that has not been seen before. The ultrathin form factor allows gamers to play on a gaming grade surface that is literally a skin of the desktop.
TECH SPECS
Adhesive bottom to stick on any surface
Extra thin to avoid any restrictions to your gaming experience
Excellent tracking quality for both laser and optical mice
Approximate Size : 330 mm / 13.00" (Length) x 225 mm / 8.87" (Width) x 3 mm / 0.12" (Height)
Approximate Weight: 20 g / 0.04 lbs
