The Razer Ouroboros was designed specially by our team of ergonomic scientists and engineers to create the most comfortable ambidextrous mouse. Extensive ergonomic research was conducted based on scientific studies from the Razer ergonomic scientists, industrial designers and by extensive testing and trials together with numerous feedback we've gathered from our pro-gamers and the community. Our ergonomists derived that there are essentially 3 key factors in an ambidextrous mouse.
Adjustable Length The length of the Razer Ouroboros is capable of extending up to 15mm /0.59 inches, via the adjustable rear panel. This length adjustment makes the Razer Ouroboros suitable for a wide range of people with varying hand sizes, as well as caters to various grip types, as Palm grip users generally prefer larger mice
Adjustable Back Arch The back tilt angle of the mouse is customizable by adjusting the palm rest, creating a flatter or steeper arch depending on your hand profile, ensuring that the back of the mouse rests in your palm comfortably. This is especially important for Claw grip users, who use the pit of their palms to stabilize the mouse when swiping or lifting.
Interchangeable Side Panels The two types of side panels modifies the side grip profile of the mouse, ensuring your thumb and pinkie are well placed. Claw or fingertip users will prefer the textured Finger Grip Panel that maintains the narrow footprint of the mouse while palm grip users can rest their pinkie on the winged Finger Rest Panel to ensure smooth and precise swiping.
8200DPI 4G Dual Sensor System Experience the new pro-gaming standard of precision with the 8200dpi 4G Dual Sensor System, outfitted with a laser and an optical sensor to accurately calibrate the mouse to any surface for exceptional tracking.
1ms Gaming-Grade Wireless Technology Unrivaled gaming-grade wireless technology means that the Razer Ouroboros performs as well cordless as it does corded, giving you total freedom of motion as you crush the competition.
Dedicated DPI Clutch Trigger Sometimes in the heat of battle there's a need to slow down and focus to get that perfect headshot off in sniper mode. With our dedicated DPI clutch trigger, you can temporarily decrease / increase your DPI for pinpoint precision at a squeeze of the trigger. Release it to unleash your usual lightning fast speed.
Powered by a single AA battery The Razer Ouroboros is powered by a single AA Battery, and it supports 12hours of continuous gaming. We've included a rechargeable nickel metal hydride (NiMH) battery, but it will also run on normal AA alkaline batteries for those times you need a quick swap, otherwise, just plug your mouse in wired mode and you're good to go.
Synapse 2.0 Synapse 2.0 is cutting-edge intuitive proprietary software that functions as the brain of the Razer Ouroboros. Save your custom profiles and sync them from anywhere in the world through our cloud system. Automatically download driver and firmware updates easily through this unified configurator software.
Technical Specifications -Customizable ergonomics to fit all hand sizes and grip-styles -8200dpi 4G Dual Sensor System -Gaming-grade wireless technology with dock -Razer Synapse 2.0 enabled -11 programmable Hyperesponse buttons -1000Hz Ultrapolling / 1ms response time -Up to 200 inches per second / 50g acceleration -Approximate Size: 122 mm to 137 mm / 4.80" to 5.39" (Length) x 71 mm / 2.80" (Width) x 42 mm / 1.65" (Height) -Approximate Weight: 115 g / 0.25 lbs. (without battery) to 135 g / 0.29 lbs. (with battery) -Battery life: (Approx) 12 hrs (continuous gaming)
Hardware Requirements PC / Mac with USB port Windows® 7 / Windows Vista® / Windows® XP (32-bit)/ Mac OS X (v10.6-10.7 and above) Internet connection 100MB of free hard disk space
The Razer Ouroboros features customizable ambidextrous ergonomics with an adjustable arched palm rest and back, as well as two interchangeable side panels. This gaming mouse will perfectly fit any and every hand curvature and grip-style, ensuring optimum comfort and minimal fatigue during extended play for every gamer - especially you.
4G dual sensor system
Experience the pro-gaming standard of precision with the 8200 dpi 4G dual sensor system, outfitted with a laser and an optical sensor to accurately calibrate the mouse to any surface for exceptional tracking. The Razer Ouroboros not only matches the speed of your swipes, no matter your play style, but also gives you adjustable liftoff tracking distance, empowering you with more control than ever.
1 ms gaming-grade wireless technology
Unrivaled gaming-grade wireless technology means that the Razer Ouroboros performs as well cordless as it does corded, giving you total freedom of motion as you crush the competition. With a 1 ms response rate, your command is executed first even if you and your opponent react at the same time. When you need to charge the mouse, use its stylish dock, or plug the cord in to keep on gaming.
Razer Ouroboros - mouse - USB
Mouse
Wireless, wired - USB
Orientation
Right and left-handed
7.1 cm x 13.7 cm x 4.2 cm
115 g
Wireless Receiver
Multi-functional Charging/Receiver Dock
Movement Detection Technology
Laser
Buttons Qty
11
Movement Resolution
8200 dpi
Performance
50 G maximum acceleration, 1 ms response time, 1000 reports per second, 200 inches per second
