Designed and tested by top streamers, the Razer Kiyo is a desktop streaming camera with a powerful, multi-step ring light that you can dim or brighten on command, with the ability to stream at 60 fps for full gaming fidelity. It's the perfect camera for professional streaming.
Spotlight Your Stream
Designed and tested by top streamers, the Razer Kiyo is a desktop streaming camera with a powerful, multi-step ring light that you can dim or brighten on command, with the ability to stream at 60 fps for full gaming fidelity. It’s the perfect camera for professional streaming.
Ring Light, Camera, Action
Forget setting up several lights just to get decent on-camera illumination. The Razer Kiyo maintains even and flattering lighting on you, and eliminates harsh shadows. Plus, with adjustable brightness levels, getting the right amount is a breeze.
Sharper and Smoother
With 720p resolution at 60 fps, the Razer Kiyo maintains visual fidelity when you stream. This means that viewers can be completely immersed the way you are, with footage just the way you see it in-game. Also streams in 1080 resolution at 30fps for Full HD.
Made for Ultimate Compatibility
The Razer Kiyo supports streaming on popular platforms like Open Broadcaster Software and Xsplit, so you can continue using your preferred streaming platform of choice to reach your audiences.
