Console-Quality Mobile Gaming Controls
The Razer Kishi V2 is designed to meet the standards of competitive console controllers with cutting edge microswitch buttons, analog triggers, and programmable macros.
Extendable Bridge for a Universal Fit with USB C
Compatible with most modern Android devices (Android 12 and up) and iPhone 15 - The Kishi V2’s USB C connection and extendable bridge perfectly secures smartphones in place while gaming.
Stream PC and Console Games
Use Kishi V2 to play full PC and console games directly on your phone, with support for the biggest game streaming apps - Stream from your own device or play from the cloud (Third party hardware and services may be required).
Optimized for Maximum Performance
By utilizing your smartphone’s TYPE C connection, Kishi V2 eliminates input latency, allowing for responsive, seamless control - and features passthrough charging so you can power your phone as you game.
Powered by the Razer Nexus App
Launch your games, customize your controls, record and share gameplay, and keep your Kishi V2 updated with the app that can be brought up at the touch of a dedicated button.
Virtual Controller Mode
Use Virtual Controller Mode to remap touch screen controls to the Kishi V2, adding controller compatibility to many of the biggest mobile games.
Requires - Android 12 or higher | iOS 17
