Razer PC Remote Play
The power of your gaming rig now fits in your pocket - Stream your favorite games using your PC, launch them directly from your mobile device, and take your immersion to the next level with the sharpest, smoothest visuals.
Full-sized Form for Phones and iPad Mini
Console gaming form factor meets Mobile Gaming convenience - Game directly on your phone or unlock new levels of mobile gaming with tablets up to 8-inches for a view worthy of the best AAA games.
Pro-Grade Console Controls & Ergonomics on Mobile
Dominate Mobile Gaming with the esports-grade performance and comfort of Razer’s Pro console controllers - Featuring Mecha-tactile 8-way d-pad & action buttons, Hall Effect triggers, programmable buttons, and ultra-durable TPSiV analog sticks.
Razer Sensa HD Haptics and Chroma RGB
Experience high-fidelity haptics that are stronger, more detailed, and more nuanced than traditional console controller vibrations, complete with dynamic addressable Chroma RGB lighting.
Seamless Connectivity and Convenience
Enjoy low-latency gaming and smooth audio with plug-and-play convenience - Power your device as you game with passthrough charging via USB-C and get to the action fast by keeping your phone in its case - 3,5 mm audio jack for fitting headsets.
Powered by the Razer Nexus App
Launch your games, customize your controls, record and share gameplay, and keep your Kishi Ultra updated with an app that can be brought up at the touch of a dedicated button (Razer Nexus does not require a fee/subscription, some apps within Razer Nexus do).
Virtual Controller Mode
Use Virtual Controller Mode to remap touch screen controls to the Kishi Ultra, adding controller compatibility to many of the biggest mobile games (Feature available for Android devices only).
