Razer HyperSpeed Wireless
for gaming grade, low latency performance
Delivering an ultra-fast 2.4GHz wireless connection via its included USB-C dongle, the headset ensures seamless, low latency audio that meets the demands of competitive gaming on numerous platforms.
Razer™ TriForce 50mm Drivers
for powerful, lifelike audio
The Razer Kaira HyperSpeed features cutting-edge drivers that can tune highs, mids, and lows separately—producing brighter, clearer sound with richer trebles and more powerful bass.
Razer™ HyperClear Cardioid Mic
for enhanced voice capture
The bendable mic has been fine-tuned to suppress background noise from the back and sides for greater voice isolation, ensuring you’ll always be heard loud and clear.
Razer™ FlowKnit Memory Foam Cushions
for long-lasting comfort
The ear cushions’ breathable weave minimizes sweat and heat build-up, while their ultra-soft foam greatly reduces the headset’s clamping force for snug, comfortable support during gaming marathons.
Low Latency Bluetooth Mode
for seamless mobile and handheld gaming
Toggle Gaming Mode when connected to a Bluetooth device by triple-tap and holding the SmartSwitch Button—for reduced audio latency and smoother performance with smartphones, tablets, and handheld gaming devices.
Up to 35 Hours of Battery Life
for all-day gaming
Enjoy countless hours of non-stop use with optimized power management that allows for more gaming and less charging.
Manufacturer Warranty - 2 Years
