FOR THE PRO
Instantly elevate your play with the champ of esports gaming keyboards—the Razer Huntsman V3 Pro. Supercharged by Rapid Trigger Mode, tap into our latest analog optical switches and execute repeated inputs at unfair speeds, complete with adjustable actuation for truly customized performance.
RAZER™ ANALOG OPTICAL SWITCHES GEN-2
Rapid Trigger and Adjustable Actuation
Max out on precision and response with an esports keyboard featuring our most advanced switches, including Rapid Trigger for ultra-fast repeated inputs, a 0.1 to 4.0 mm adjustable actuation range, and a 100-million keystroke lifespan.
RAPID TRIGGER MODE
Instead of a fixed reset point, keys reset instantly with an upward motion as low as 0.1 mm. This allows for faster repeated keystrokes compared to standard keyboards, which significantly enhances in-game responsiveness.
SNAP TAP MODE
Prioritize the latest input between two selected keys without having to release the previous one. Enjoy more responsive inputs for near-instant directional changes.
ADJUSTABLE ACTUATION
Supporting a full range of actuation from 0.1 to 4.0 mm, customize the switches to be as sensitive as you want and achieve a setting that best suits your playstyle.
40 G ACTUATION FORCE
Enjoy greater response with a lighter actuation force that lets you play and react quicker than ever before. From counter-strafing to aiming to dodging, gain a split-second advantage you need to come out on top in every exchange.
