Armed with the same lightning-fast response that's a hallmark of all optical keyboards, perform quicker keystrokes with switches that have a shorter actuation height for reduced key travel.
Ultra-low-latency gaming
Experience ultra-low-latency gaming with the 2.4 GHz connection that's even faster.
Versatile and convenient
Use the wireless keyboard on your PC, tablet, and more, as you seamlessly switch between devices.
Non-stop use
With impressive power efficiency to support its optical switches and bright RGB backlight, the Razer DeathStalker V2 Pro has a long battery life.
Long-lasting ergonomics
The keyboard's slim profile ensures neutral hand positioning for long hours of use with little strain, while its aluminum alloy top plate provides greater durability with a satisfying heft.
Convenient control
Configure them to pause, play, skip and tweak everything from brightness to volume - the ultimate convenience as you enjoy your entertainment.
Razer DeathStalker V2 Pro - keyboard - QWERTY - UK Input Device
