Just when you thought a gaming laptop couldn't be any more beastly - introducing the Razer Blade 15. Enjoy unrivaled performance packed into a thin chassis.
Experience advanced power with an Intel Core processor. Intel's 12th Gen processors bring a revolutionary design with a performance hybrid architecture that combines performance-cores with efficient-cores, offering users the freedom to chat, browse, stream, edit, record, and play. Integrated Killer Wi-Fi 6E AX16900 (Gig+) delivers the next-generation Wi-Fi technology with packet prioritization for a better gaming experience.
NVIDIA GeForce RTX 30 Series graphics - the ultimate play
NVIDIA GeForce RTX 30 Series Laptop GPUs power the world's fastest laptops for gamers and creators. They're built with Ampere - NVIDIA's 2nd gen RTX architecture - to give you the most realistic ray-traced graphics and cutting-edge AI features like NVIDIA DLSS. Plus, Max-Q Technologies unleash the power of AI to make thin, high-performance laptops that are faster and better than ever.
Next-gen DDR5 (4800MHz) memory - enhanced response times
Feel the boost with an increase of 1600MHz compared to DDR4, as you enjoy a quicker, smoother experience when loading applications, running games, and performing other everyday PC tasks.
Optimal thermal performance
The Razer Blade 15 efficiently dissipates heat through the evaporation and condensation of an internal fluid - a design which has enabled the laptop to achieve its thin profile. Upgraded with more fins, fans, and a larger liquid capacity, the system maximizes its nanoparticle thermal blockers and server-grade components to maximize thermal threshold and squeeze every ounce of FPS out of the laptop.
Powered by Razer Chroma RGB
Personalize the RGB gaming keyboard with over 16.8 million colors and a suite of effects to choose from. Enjoy greater immersion with dynamic lighting effects that occur as you game on over 150 Chroma-integrated titles such as Fortnite, Apex Legends, Warframe, and more.
Lots and lots of ports
The Razer Blade 15 is equipped with advanced connectivity to accommodate a wide range of devices. It features Wi-Fi 6E (802.11ax), Bluetooth 5.2, Thunderbolt 4, and plenty of ports for external displays and peripherals.
THX Spatial Audio
An advanced 7.1 surround sound that provides pinpoint positional accuracy when using headphones and speakers, to deliver immersive, lifelike audio for stereo and multi-channel content alike.
Precise glass touchpad
A large, clickable glass touchpad with Microsoft Precision Touchpad support means smooth and precise control, including a range of gestures for expanded navigation.
Advanced control system
Take full control with the Razer Synapse 3, from customizing lighting, managing profiles, adjusting fans, and even stepping up graphics performance in Gaming Mode.
