J100 supports SAS, SATA and SSD drive configurations, allows IT administrators to flexible deploy system depending on their performance and capacity needs.
With 6G SAS wide ports for host connectivity, J100 provide up to 24 Gb high bandwidth, allowing user to deploy a cost effective JBOD without sacrificing performance.
Compatible with all major RAID card and HBA, J100 can be upgraded to a direct attached storage (DAS), allow users to gain maximum benefits from limited resource.
By utilizing 80 plus gold power supplies, J100 achieve up to 92% power efficiency, allowing users to gain 12% more converting rate than other JBOD in the same segment.
