Microsoft Active Directory (AD), Apple Bonjour Protocol, DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), SFTP
Hardware encryption, VPN support, trunking, LDAP support, wake on LAN (WOL), Syslog support, manageable, E-mail alert, print server, IPv6 support, 256-bit encryption, proxy server, backup server, download client, file sharing, event log, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, SSH support, iTunes server, Jumbo Frames support, DHCP server, FTP server, SMS alert, BitTorrent Client, reset button, bandwidth control, IPv4 support, surveillance station, teaming support, DLNA Media Server, Apple Time Machine compatible, DHCP client, e-mail notification, cloud backup, VPN Server, SFTP client, SNMP support, Apple AirPlay, Dropbox support, Real-time Remote Replication (RTRR), Google Drive support
Encryption Algorithm
SSL, TLS, 256-bit AES
DLNA CERTIFIED, UPnP
Security DVR
IP Cameras Supported
72
Expansion Bays
8 (total) / 8 (free) x hot-swap - 2.5" / 3.5"
Expansion Slots
2 x SO-DIMM 204-pin , 1 (total) / 1 (free) x PCI Express 2.0 x2
2 x Ethernet 1000Base-T - RJ-45 , 4 x USB 3.0 - Type A , 2 x Ethernet 10Gb - SFP+ , 1 x management
2 x network cable
Security lock slot (cable lock sold separately), audible alarm, built-in 2 cooling fans, scheduled power on/off
Internal power supply
Installed Qty
2
Max Supported Qty
2
64.36 Watt
Power Provided
250 Watt
Storage Operating System
QNAP QTS 4.3
UNIX, Linux, Apple MacOS X, Microsoft Windows 7, Windows 8, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2
