This premium swing arm wall mount provides the perfect solution for all large LED, LCD and Plasma television screens. With the combination of both the cantilever and tilting functions it enables you to adjust the position of the television to fit all purposes. The bracket includes an integrated spirit level helping accurate alignment installation, and an easy grip dial to enable tool-less bracket tilting.
- Distinctive chic design
- -10° to +15° up and down tilt
- Built-in screen level adjustment -4° to +4°
- Universal hole patterns up to 600 x 400mm
- VESA compliant: 100x100, 200x100, 200x200, 400x200, 400x400, 600x400
- Integrated bubble level assures easy installation alignment
- Locking hole design for anti-theft (requires a padlock)
- Mounting profile: 77-548mm
- Supports flat panel tv up to 40kgs
