Back
Refinements
Promethean Projector Upgrade - with PRM-35V DLP Short Throw Projector a
Quicklinx:
9HBPWS00
Mfr#:
AB+2V2-64A-UPG-DST
Back
Marketing description is not available.
Promethean PRM-45A Projector upgrade - DLP projector - 3D
DLP projector - 720p
3D Capable
Yes (transmitter and 3D glasses sold separately)
Contrast Ratio
2100:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Bulb type
240 Watt
Video Input
(PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC)
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
AC 120/230 V
300 Watt
31.4 cm x 21.6 cm x 12.6 cm
3.18 kg
3D Capable
Projector
Contrast Ratio
2100:1
Image Size
178 cm - 254 cm
Projection Distance
0.779 m - 1.127 m
Resolution
WXGA - WXGA (1280 x 800)
Native Aspect Ratio
16:10
Max Sync Rate (V x H)
120 Hz x 91.4 kHz
Bulb type
240 Watt
Lens
Focus Type
Manual
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
Video Interfaces
VGA, HDMI, composite video, S-Video
Video Modes
2 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x S-video input - 4 pin mini-DIN , 1 x composite video input - RCA , 1 x network - RJ-45 , 2 x HDMI input - 19 pin HDMI Type A , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm
Security Features
FCC Class B certified, UL, TUV GS, NOM, SASO, CB, CCC, PSB, EK, EAC
Power Source
AC
AC 120/230 V
300 Watt
Power Consumption Stand by
0.5 Watt
31.4 cm
21.6 cm
12.6 cm
3.18 kg
5 °C
