Equipped with both 128-bit and 256-bit AES encryption, the Poly Studio X30 ensures your communications are secure, providing peace of mind in every interaction.
Featuring a wide range of interfaces including HDMI input and output, SuperSpeed USB 3.0, USB-C, and Ethernet, the Poly Studio X30 offers versatile connectivity options for a seamless user experience.
With support for multiple video codecs including H.264 High Profile and H.265, and voice codecs like G.711 and G.722, the Poly Studio X30 delivers crystal-clear audio and high-definition video for a high-quality conferencing experience.
The integrated camera with a 120° field of view alongside support for up to UHD (3840 x 2160) resolution ensures that every participant is seen in stunning clarity during meetings.
Incorporating MIMO and Polycom Lost Packet Recovery (LPR) technology, the Poly Studio X30 offers a stable and efficient networking experience, ensuring your meetings run smoothly without interruption.
- Poly Studio X30 - video conferencing kit - with Poly TC8
- Video conferencing kit
- Kit Content
- Touchscreen console, video bar
- VoIP Protocols
- H.323, SIP
- Codec
- H.264, H.265, H.264 High Profile, G.711, G.722, G.728, G.729a, G.722.1, G.722.1c, AAC-LD, G.719
- Localisation
- United Kingdom
- Video Input
- Digital camera - HDMI input
- Video Output
- 3840 x 2160
- Audio Input
- Four microphones
- Audio Output
- Speaker(s) - mono
- Input Device
- 8" touchscreen (wired)
- Networking
- Network adapter - Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 5.0
- Power
- AC 120/230 V (50/60 Hz)
- Software Certification
- Zoom Certified
- 1-year warranty
- Bundled with
- Poly TC8
- Kit Content
- VoIP Protocols
- H.323, SIP
- Voice Codecs
- G.711, G.722, G.728, G.729a, G.722.1, G.722.1c, AAC-LD, G.719
- Video Codecs
- Security
- 128 bit AES, 256 bit AES, TLS 1.0, TLS 1.1, TLS 1.2, H.235.6, FIPS 140-2
- Network Features
- Authenticated access to admin menus, web interface, and APIs, local account password policy configuration, security profiles, local account and login port lockout, secure defaults, remote logging with support for TLS, active directory external authentication
- Dimensions & Weight Details
- Touch screen - Width 20.5 cm Depth 7.9 cm Height 12.3 cm Weight 812 g , Video bar - Width 44.18 cm Depth 6.16 cm Height 6.25 cm Weight 730 g
- Built-in Devices
- Speaker, camera, 4 microphones
- Localisation
- United Kingdom
- Bundled with
- Poly TC8
Video Input
- Digital camera - integrated
- Interface Type
- HDMI input
- Digital Video Capture Resolution
- 1280 x 720, 1024 x 768, 1280 x 1024, 1920 x 1080, 3840 x 2160, 1920 x 1200, 1680 x 1050, 1400 x 1050
- Video Modes
- 720/60p, 1080/60p, 1080/30p, 720/30p, 4K
- Digital Zoom
- 4
- Interactive whiteboard compatibility, 120° field of view, automatic speaker tracking, automatic group framing, Poly content sharing, content annotation, UHD 2160p (4K) capture resolution
Video Output
- Max External Resolution
- 3840 x 2160
- Supported Display Graphics
- XGA (1024x768), SXGA (1280x1024), SXGA+ (1400x1050), HDTV (1920x1080), WUXGA (1920 x 1200), HD (1280 x 720), WSXGA+ (1680 x 1050), UHD (3840 x 2160)
- Analogue Video Signal
- (NTSC, PAL)
- Digital Video Standard
- High-Definition Multimedia Interface (HDMI)
Audio Input
- Four microphones
Audio Output
- Speaker(s)
- Sound Output Mode
- Mono
Input Device
- 8" touchscreen
- Connectivity Technology
- Wired
- Network adapter
- Wireless, wired
- Data Link Protocol
- OCSP support, auto-uplink (auto MDI/MDI-X), MIMO technology, IPv4 support, Wi-Fi Miracast ready, Apple AirPlay, Polycom Lost Packet Recovery (LPR) technology, Simple Certificate Enrollment Protocol (SCEP)
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 5.0
- 1 x audio / video - HDMI input - 19 pin HDMI Type A , 1 x audio / video - HDMI output - 19 pin HDMI Type A , 1 x SuperSpeed USB 3.0 , 1 x USB-C - 24 pin USB-C , 1 x network - Ethernet 10Base-T/100Base-TX/1000Base-T - RJ-45
- Cables Included
- 1 x HDMI cable - 1.83 m , 1 x network cable - 4.57 m
- Included Accessories
- Clamp, cables
- Zoom Certified
- FIPS 140-2
- Power Device
- Power adapter - external
- Voltage Required
- Limited warranty - parts and labour - 1 year
- 0 °C
- 40 °C
- 5 - 90% (non-condensing)
