Power up productivity for office workers with the Voyager 4200 UC Series Bluetooth wireless headsets. Connecting is seamless - smartphone or computer. Outstanding audio, freedom to roam.
Give office workers flexibility and hands-free productivity with up to 30 meters / 98 feet of Bluetooth wireless range with the included BT600 USB adapter.
Connectivity options
Easy connectivity options for your different communication needs: BT600 USB Bluetooth adapter to connect to your PC and directly to the mobile phone via Bluetooth .
No need for battery anxiety
Keep your headset fully charged using a desktop charging stand. You can also extend the battery life by using it corded, with audio over USB mode.
Smart sensors
Dynamic Mute Alert senses and tells you when talking while muted. And the on-ear indicator light flashes to let others around you know you are on a call to keep you distraction free.
Easy management via Poly Lens
Take control of your deployment from anywhere via remote management with Poly Lens cloud-based device management software.
Certified for Microsoft Teams
Full Microsoft Teams certification takes your Microsoft Teams experience to the next level with a button for instant access to the app and more.
HP Poly - for Microsoft Teams - wireless headset system base for Bluetooth headset
Wireless headset system base
Intended For
Bluetooth headset
Package Content
Wireless headset system base, USB cable, telephone interface cable, power adapter
