Keep the conversation going whenever, wherever – at work. Built for on-site employees the Poly Rove wireless IP phone solution delivers the sweet freedom to move and the flexibility to scale as you grow. Dropped phone? No problem. You're covered with ruggedized IP65, dust-tight, and water-resistant technology. Protection doesn't stop there. Built to stay cleaner for longer with Microban antimicrobial product protection. And guard your most critical conversations with DECT technology. We've got you covered. Built to last. Built to scale. Never miss a call. Communicate hands-free with a Poly headset using the 3.5mm connection.
