Designed for Xbox One, the RIG 500HX headset delivers performance audio you can count on with durable, lightweight comfort for competitive challenges.
FOCUS WINS
The durable yet lightweight frame lets you configure components for endurance or focus. The included isolating earcups immerse you in the game, blocking out distracting background noise.
CONFIGURE TO WIN
RIG 500 is designed to let you change out components to match your needs. Opt for immersive, isolating cups to game in peace or choose the open, vented cups to keep your cool during long sessions. The flexible headset frame can be swapped out for translucent or camo colour options.
PERFORMANCE AUDIO
Audio fidelity that gives you an edge. Dynamic, 40mm drivers are matched with low-frequency resonators to boost the bass response without destroying crucial mids and highs. The noise-cancelling boom mic flips up to mute, making it perfect for solo campaigns.
