Ideal in the car - more talk + tunes, less charging
The Plantronics® M55™ Bluetooth® headset features DeepSleep™ mode, which can extend the standard 16 days standby time up to 5 months. Noise and wind reduction means your voice is heard on calls and not the disruptive background noises. You can listen to music, Internet radio, or GPS and even charge in the car with the discreet car charger. While whispered alerts keep you informed about battery level, Bluetooth connection, and more. Forget buttons, use your voice to take calls - just say "answer". And no matter how long the call takes, the super soft ear tip will keep you comfortable.
DeepSleep™ mode extends battery life
Stream music and media
Just say "answer" to take calls
Reduces background noise
Alerts for battery level and more
Onscreen headset battery meter
