The Plantronics Blackwire 3200 Series headsets are durable, comfortable, and easy to deploy. Blackwire 3200 Series with Plantronics signature audio provides excellent features at a price you can afford.
Offering PC wideband, a noise-canceling microphone and hi-fi stereo sound, Blackwire 3200 Series headsets provide a signature truly outstanding audio experience - ideal for voice, music and multimedia. The dynamic EQ feature optimizes your voice quality when you're on a call and automatically adjusts the EQ settings when you're listening to music or multimedia.
Connectivity options
Ideal for knowledge workers who need a solution for managing calls on their PC, mobile phone or tablet. Blackwire 3200 Series offers the comfort and durability of corded combined with flexibility - at an entry-level price point. You can manage calls from your PC or tablet with standard USB or USB-C connectivity. The C3215 models offer a 3.5 mm connection option for your wireless device.
Comfort and portability
Enjoy the security of a comfortable fit. A lightweight metal headband offers durability and a custom fit. Leatherette ear cushions fold flat for easy portability.
Poly Blackwire C3215 - headset - USB, 3.5 mm jack
Headset - wired - USB, 3.5 mm jack
Compatibility
Mac, Windows
Recommended Use
Portable electronics, computer - communication
Headphones Form Factor
On-ear
Wired
Sound Output Mode
Mono
Audio Specifications
Frequency Response 20 - 20000 Hz
Microphone
Boom
Controls
Mute, volume, answer/end, hold, redial
Series
3200 Series
Compatibility
Mac, Windows
Dimensions & Weight Details
96 g
Earpad Material
Leatherette
Recommended Use
Protection
Hearing protection
Audio Output
On-ear
Wired
Sound Output Mode
Mono
Frequency Response
20 - 20000 Hz
In-Cord Volume Control
SoundGuard Technology
Microphone
Boom
Headset microphone
Frequency Response
100 - 10000 Hz
Remote Control
Controls
Connector Type
USB (4 PIN USB Type A) , Headset (mini-phone stereo 3.5 mm 4-pole)
