Music makes any moment more personal. Get lost in rich, lifelike audio and make every moment your own. With hours of continuous wireless use, you’re going to need a longer playlist.
- Up to 24 hours continuous wireless streaming
- Automatic music play/pause when headphones are put on/removed
- DeepSleep mode puts headphones into hibernation device, when away from device, extending battery life up to 6 months
- Up to 100m* range from Class 1 Bluetooth device
- On-demand Active Noise Cancelling (ANC)
BackBeat PRO: Wireless, noise cancelling headphones + mic
Get lost in rich, lifelike audio and make every moment your own. With up to 24 hours of continuous wireless use, you’re going to need a longer playlist. Immerse yourself in music and block out the noise whether working, traveling, or just relaxing.
At work, you need to be able to tune out distractions and tune into your thoughts. On the go, you need a soundtrack to what you’re seeing. At home, you need music that moves you but does not disturb others. Plantronics BackBeat PRO active noise cancelling headphones deliver all the brilliance and nuance of your music plus the emotive clarity of your voice for connecting with colleagues, friends, or family wherever you go. With up to 24 hours of continuous wireless use, you’re going to need a longer playlist.
IMMERSE IN YOUR MUSIC
With 50+ years of industry-leading expertise in audio and communication technologies and design, Plantronics understands how to deliver all the rich bass, crisp highs, and natural midtones of your music through headphones so comfortable, you won’t want to take them off.
CREATE A LONGER PLAYLIST
With up to 24 hours of continuous streaming power and a handy audio cable, you can keep the music and movies going as long as you like. Power-saving features such as automatically pausing the streaming audio and ANC when you slip off your headphones plus an out-of range hibernation mode also keep the battery charged longer.
TUNE OUT DISTRACTIONS
Use it with or without your music to help you focus or just get lost in the moment. When you want to check back in with the world around you, our exclusive OpenMic feature lets you control the level of ambient noise you hear.
TAKE YOUR MUSIC WITH YOU
Wander away from your device and control your listening experience with easy, on-ear controls and familiar-feeling dials. If call rings in while you’re watching a movie on your tablet, seamlessly switch connections to answer your smartphone.
• Plantronics signature audio, open and realistic
• On-demand Active Noise Cancelling (ANC)
• Up to 24 hours continuous wireless streaming
• Up to 100m* range from Class 1 Bluetooth device
• OpenMic feature lets you hear your surroundings
• Automatic music play/pause when headphones are put on/removed
• Connect and switch audio between a smartphone and tablet
• DeepSleep mode puts headphones into hibernation device, when away from device, extending battery life up to 6 months
• Cushioned, over-the ear design for long wearing comfort
• 14 language options for status alerts (remaining battery, etc. )
• Durable nylon travel sleeve protects headphones
Box Contains
- Wireless USB Charger
- Phone Jack
- Case
- Headphones 200590-05
