Push yourself with wireless sport headphones that are as unstoppable as you are: BackBeat FIT. Flexible, durable and waterproof, they stay comfortably in place through your most intense workouts.
As unstoppable as you are When it comes to your workout, nothing gets in your way. Stay focused and distraction-free with wireless sport headphones that stay comfortably in place. BackBeat FIT provides superior stability with a behind-the-ear design and comfortable ear tip. The only reminder that you're wearing them is the rich sound of your favourite playlist or podcast pushing you to your next personal best.
Engineered for sport Ready to go the extra mile -- or ten? Flexible and durable, BackBeat FIT pushes you further, withstanding the rain or a rinse under the tap with a waterproof design that meets the IP57 rating and an additional sweat-proof nano-coating. And whether you wear them running on a road or on a trail, the open ear tip design lets you hear the sounds around you.
WATERPROOF Waterproof design that meets IP57 rating plus sweat-proof nano-coating
8-HR BATTERY Power through a week of workouts from a single charge
SECURE FIT Stability and comfort with a flexible neckband design
OPEN EAR TIP DESIGN Enjoy your music while remaining alert to your surroundings
You never quit. Neither should your headphones. With up to eight hours of listening from a single charge, BackBeat FIT helps you power through a full week of workouts. Subtle voice alerts let you know how much listening time you have left, and the 15-minute quick charge provides an hour of play to get you through the day's challenge.
What's in the box?
BackBeat FIT Wireless Headphones
Plantronics BackBeat FIT carry case
Micro USB charging cable
Quick guide/ manual
Poly - Plantronics Backbeat FIT - earphones with mic
Earphones - Bluetooth - wireless
Recommended Use
Portable electronics, phone
Headphones Form Factor
Ear-bud - behind-the-neck mount
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 3.0
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 50 - 20000 Hz - Sensitivity 105 dB/mW
Controls
Answer/end, play/pause, next/previous track
24 g
Recommended Use
Protection
Waterproof
Max Operating Distance
10 m
Audio Output
Wireless
Wireless Technology
Bluetooth
Bluetooth Version
Bluetooth 3.0
Bluetooth Profiles
Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
