The HP Poly audio cable is designed to provide a seamless connection between your audio devices. With a M22 connector on one end and a Quick Disconnect on the other, it ensures a stable and clear audio transmission, making it ideal for high-quality audio applications.
Versatile compatibility
This audio cable's unique connector types, M22 and Quick Disconnect, offer broad compatibility with a range of audio equipment. Whether you're connecting professional audio gear or personal devices, this cable ensures reliable performance.
Poly audio cable
Cable
Audio cable
Connector
M22
Connector (Second End)
Quick Disconnect
Poly EncorePro
Cable Type
Audio cable
Connector
M22
Quick Disconnect
Shipping Width
13 cm
Shipping Depth
21 cm
Shipping Height
7 cm
Shipping Weight
300 g
Poly EncorePro
