The NVIDIA Quadro K2200 delivers exceptional power-efficient 3D application performance. 4 GB of GDDR5 GPU memory with fast bandwidth enables you to create large, complex models, and a flexible single-slot form factor makes it compatible with even the most space and power-constrained chassis. Plus, an all-new display engine drives up to four displays with DisplayPort 1.2 support for ultra-high resolutions up to 3840 x 2160 at 60 Hz with 30-bit color. Designed and built specifically for professional workstations, NVIDIA Quadro GPUs power more than 200 professional applications across a broad range of industries including manufacturing, media and entertainment, sciences, and energy. Professionals trust them to realize their most ambitious visions - whether its product design, visualization and simulation, or spectacular visual storytelling - and get results to market faster.
With dual DVI-I (dual link) and DisplayPort outputs, the NVIDIA Quadro K2200 graphics card offers versatile connectivity options for a wide range of display types. Whether connecting to high-resolution monitors or integrating with a complex workstation setup, this card ensures seamless compatibility.
Robust video memory
Equipped with 2 GB of GDDR5 SDRAM and a 128-bit bus width, the NVIDIA Quadro K2200 delivers exceptional graphics performance and speed. This ample video memory allows professionals to work on complex models and simulations without compromising on speed or quality.
Advanced video features
The NVIDIA Quadro K2200 is designed to enhance your visual computing experience. It supports a variety of APIs including DirectX 11.2 and OpenGL 4.5, and comes with features like NVIDIA Mosaic and NVIDIA nVIEW Multi-Display Technology, enabling expansive visual workspaces and increased productivity.
Energy efficient design
ENERGY STAR certification signifies that the NVIDIA Quadro K2200 not only delivers powerful performance but also operates efficiently. This energy-efficient design helps reduce operational costs and environmental impact, making it an ideal choice for eco-conscious professionals.
