The GeForce GTX 970 is a high-performance graphics card designed for serious gaming. Powered by NVIDIA Maxwell architecture, it features advanced technologies and class-leading graphics for incredible gaming experiences.
This is NVIDIA's most advanced architecture ever, delivering incredible performance and unmatched power efficiency. Plus, it offers cutting-edge features like advanced sampling and Dynamic Super Resolution technology that delivers 4K-quality gaming - even on 1080p displays.
Multi-Frame sampled Anti-Aliasing (MFAA)
MFAA delivers a 30% performance boost while maintaining smooth, high-quality edges by alternating sample calculations across each frame and each pixel.Learn more
Dynamic Super Resolution (DSR)
This innovative feature can delivers 4K fidelity to 1080p displays for exceptional detail and image quality.
Voxel Global Illumination (VXGI)
Part of the NVIDIA GameWorks library for developers, VXGI accelerates dynamic lighting effects for a truly immersive, cinematic experience.
GeForce Experience
The easiest way to optimize your games and keep your drivers up to date, the GeForce Experience application automatically notifies you of driver releases from NVIDIA. With a single click, you'll be able to update the driver directly, without leaving your desktop. You can also capture and share 4K gameplay with NVIDIA ShadowPlay.
NVIDIA GameStream
Stream extreme GeForce GTX PC gaming experiences to portable devices like NVIDIA SHIELD with super-smooth, low-latency performance.
NVIDIA G-SYNC
This groundbreaking display technology delivers the smoothest and fastest gaming experience ever. G-SYNC's revolutionary performance is achieved by synchronizing display refresh rates to the GPU in your GeForce GTX-powered PC, eliminating screen tearing and minimizing display stutter and input lag. Scenes appear instantly, objects look sharper, and gameplay is super smooth, giving you a stunning visual experience and a serious competitive edge.
NVIDIA GPU Boost 2.0
This innovative technology allows gamers to push PC performance to the maximum with precise controls. It intelligently monitors work with advanced controls like GPU temperature target, overclocking, and overvoltage to ensure that the GPU works at peak performance.
NVIDIA Adaptive VSync
Nothing is more distracting than frame rate stuttering and screen tearing. The first tends to occur when frame rates are low, the second when frame rates are high. Adaptive VSync is a smarter way to render frames using NVIDIA Control Panel software. At high framerates, VSync is enabled to eliminate tearing. At low frame rates, it's disabled to minimize stuttering.
NVIDIA surround with up to four monitors
Now, you can play your favorite games across four monitors. At 5760 x 1080, the expanded field of view fully engages peripheral vision and provides for the most immersive experience in racing and flight simulators.
NVIDIA SLI technology
Used by the most demanding gamers worldwide, SLI technology lets you link up to four NVIDIA SLI-Ready cards together for astounding performance.
