Back
Accessories
PMVmounts Peerless-AV Universal Ceiling Mounted TV Bracket for 18 to 37
Quicklinx:
DP0SWS00
Mfr#:
PMVCEILINGSL
Gallery
Back
Marketing description is not available.
PMV Mounts PMVCEILINGSL bracket - for LCD display - white, satin black
Bracket - ceiling mountable
Tilt
45°
Pan
360°
Levelling
5°
Adjustments
Levelling, pan, tilt
Recommended Use
LCD display
Recommended Display Size
18"-32"
VESA Mounting Interface
Up to 400 x 300 mm
Max Load Weight
30 kg
Material
High grade steel
White, satin black
Material
High grade steel
White, satin black
AV Furniture
Bracket
Recommended Use
LCD display
Placing / Mounting
Ceiling mountable
Up to 400 x 300 mm
Cable Management
Integrated cable management
18"-32"
Tilt
45°
Pan
360°
Levelling
5°
Adjustments
Max Load Weight
30 kg
Finish
Powder coated
