200 x 200 mm, 400 x 400 mm, 300 x 300 mm, 400 x 600 mm
Max Mounting Pattern Size
800 x 400 mm
Max Load Weight
50 kg
72 cm
60 cm
170 cm
AV Furniture
Cart
Recommended Use
LCD / plasma panel
VESA Mounting Interface
800 x 400 mm
Recommended Display Size
32"-55"
Adjustments
Tilt
Max Load Weight
50 kg
Adjustable height, wheels
