Raise the power of your voice
The Plantronics M1100 headset is your smartphone assistant. Now your voice takes control to answer a call without lifting a finger. Or use the dedicated voice button to connect, pair and check status. Go beyond conversations and indulge your ears with streaming music or podcasts. You'll hear and be heard with rich clarity thanks to the triple-microphone precision and Plantronics signature audio quality. This is hands-free on a whole new level.
With Plantronics® Vocalyst™, you can let your voice do the work. Think of Vocalyst as an assistant built into your M1100 headset. When you want to do something and you need to be hands free, simply call Vocalyst using voice commands, say what you want to do and it gets done. You can respond and listen to your emails, have your SMS read aloud, record reminders and even update your Facebook status all by using your voice. You can customise your M1100 Vocalyst package, even down to the language you wish to use.
Key features
Three microphones deliver superior sound quality
AudioIQ³ and DSP reduce background noise
Convenient voice commands to control your headset
A2DP for streaming music, podcasts and more
Whispered voice alerts for low battery and more
Dedicated on/off switch preserves battery power
iPhone headset battery meter
Flexible silicone ear gel tips
Easy to put on to quickly answer calls
Lightweight and comfortable design
Battery provides up to 4 hours talk time / 7 days standby
Weighs only 9 grams
