            Philips Hue Impress Wide White & Colour Ambiance LED Smart Outdoor Wall Light Double Pack - designed for outdoors.
Add colour to your outdoors with 2x Philips Hue Impress Smart Outdoor Wall Lights [Wide]. Simply install and enjoy 16 million colours to enhance the beauty of your outdoor space to create any ambiance you like. This Philips Hue outdoor smart light is specifically designed for outdoor environments and has undergone rigorous tests to ensure performance (IP44).
Highlight the beauty of your garden with the Philips Hue Lily 4x Smart Outdoor Spotlight Base Kit. This base unit includes 4x Lily spotlights, 40W power supply and all cables to start lighting your outdoors.
What's Required? - A Philips Hue Bridge (sold separately - see item number LJMJE) is required for smart control. Simply connect your Bridge, plug in your new Philips Hue lights and take advantage of smart outdoor lighting via the Philips Hue app.
Style with Colour - Choose from 16 million colours including warm to cool white light to create the perfect ambiance for relaxing or entertaining outdoors. Discover the perfect smart lighting for parties, BBQs and more!
Plug and Play - As part of the Philips Hue low voltage range, easily extend your smart lighting to cover your entire outdoor space without needing to call the electrician.
Control Lights With Your Voice - Works with Alexa, Google Assistant and Apple HomeKit devices for hands-free voice control. Control your smart outdoor lights with simple voice commands!
- Depth: 19 CM
- Height: 24 CM
- Width: 11.7 CM
