Dim your Philips Hue lights Using the Philips Hue switch, you can smoothly dim your favorite light setting up and down.
Place it anywhere The Philips Hue Dimmer switch can be used as a normal wall switch. You can place it anywhere you want, using screws or the adhesive tape on the back plate of the switch.
No wires - battery-powered The Philips Hue dimmer switch is battery-powered, so there is no installation required.
Use as a remote control You can also use the Philips Hue dimmer switch as a remote control for your comfort.
Switch between scenes When using your dimmer switch with Philips Hue white ambiance or Philips Hue white and color ambiance products, you can use the on-button to switch between 4 light recipes, or use the Philips Hue app to configure your favorite 4 scenes. It's all up to you.
Using the Philips Hue dimmer switch, you can smoothly dim your favorite light setting up and down.
Place it where it matters
The Philips Hue dimmer switch works as a normal wall switch and dimmer. You can place it anywhere you want, using screws or the adhesive tape on the back plate of the switch.
Pick up the remote and use it wherever you want for your comfort. The control unit of the switch is magnetic and can be removed from the base plate.
No wires - battery powered
