Get started with Philips Hue white and color ambiance bulbs and experience high quality white and colored light that offers you endless possibilities.
* Paint with light * Sync lights with music and movies * Apple HomeKit compatible
Paint with light Play with light and choose from 16 million colors in the Hue app to match the light to your mood. Use a favorite photo and re-live that special moment with splashes of light. Save your favorite light settings and recall them whenever you want with the tap of a finger.
Sync lights with movies Extend your TV viewing experience to the whole room or lift your gaming experience to the next level. Download a the third party apps and discover the amazing things you can do with Philips Hue.
Sync lights with music Sync light to your favorite music and enjoy every beat to the fullest. Transform any room into a dance floor and see how light reacts to your music. Download third party apps and get the party started with Philips Hue
Apple HomeKit compatible The Philips Hue white and color ambiance starter kit is compatible with Apple HomeKit technology. Ask Siri to turn on or dim your lights or recall presets without touching a single button. Via third party apps you can even link your lights to other Apple HomeKit enabled devices.
Create your ambiance Set the right ambience for any moment with a range of beautiful, natural white light. Use the app to set any shade of white light, from cool energizing daylight to relaxing warm white light. So set the mood. Change the ambience. Feel different. Feel better.
Light for your well-being Light influences our mood, behavior, alertness and routines. Through the app, you can set the light that is optimal for your moment. Philips Hue helps you to energize, concentrate, read and relax. Customize your daily routines into moments you can enjoy. Set the mood. Change the ambiance. Feel different. Feel better.
Wake-up Ease your sleeping routine and wake up gently for a fresh start of each day. Philips Hue will help get you out of bed in a nice way. The gradually increasing light intensity gives you the feeling you are waking up naturally with sunlight - rather than the rude awakening of an alarm ringing.
Light schedules for home automation Philips Hue can make it seem like you're home when you're not, using the schedule function in the Philips Hue app. Set the lights to come on at a pre-set time, so the lights are on when you arrive home. You can even set rooms to light up at different times. And of course, you can let the lights turn off gradually in the night, so you never have to worry whether you've left any lights on
Away-from-home control You can control your lights remotely wherever you are. Check if you have forgotten to switch your lights off before you left your home, and switch them on if you are working late.
Comfort dimming Experience guaranteed smooth dimming with Philips Hue. Not too bright. Not too dark. Just right. No need for wires, an electrician or installation.
You can control your lights remotely, wherever you are. Check if you have forgotten to switch off your lights when you leave home or switch them on when you are working late. With geofencing technology, your lights can also welcome you home or turn off automatically when you leave your home. This is a smart and useful way to simplify your life and give you complete peace of mind.
Convenient dimming
Experience guaranteed easy dimming with Philips Hue. Not too bright. Not too dark. Just right. No need for cables, electricians or installation.
Program your light
Using the programming function in the Philips Hue app, your Philips Hue lights can appear to be at home. Set a switch-on time so that the light is on when you get home. You can even control the lighting in individual rooms at different times. And of course, you can gradually switch the lights off in the evening so you never have to wonder if you left the lights on again.
Philips Hue Starter Kit - wireless lighting set - LED spot light bulb x 3 - GU10 - 6.5 W - total: 19.5 W - 16 million colours - 2000-6500 K
Wireless lighting set
Light Source Type
3 x LED spot light bulb
Supported Light Bulbs Qty
50
Total Wattage
19.5 W
Dimmer
Socket Type
GU10
Wattage
6.5 W
Colour of Illumination
16 million colours
Colour Temperature
2000-6500 K
Luminous Power
230 lumens
Beam Angle
160 degree(s)
Dimmable
AC 100 - 240 V
Frequency Required
50 - 60 Hz
50
Total Wattage
19.5 W
Dimmer
Android compatible, iOS compatible
Light Source
Socket Type
GU10
Wattage
6.5 W
16 million colours
Colour Temperature
2000-6500 K
Luminous Power
230 lumens
Beam Angle
160 degree(s)
Dimmable
Lifetime
25000 hours
Upgradable firmware, instant full light
Power Requirements
AC 100 - 240 V
Frequency Required
50 - 60 Hz
Power adapter, wireless bridge, network cable
Warranty
2 years
Dimensions & Weight Details
Wireless bridge height: 2.5 cm x diameter: 10 cm , Light bulb height: 7.1 cm x diameter: 5 cm
