Smart lights, smart speaker, smart thermostat – what else could you possibly need? How about two Philips Hue smart plugs? Once you plug them in, you’ll be able to control anything connected to them using the handy smartphone app. And they don’t need a hub or anything – they have Bluetooth built-in. Want a lamp to turn on when it gets dark? Set the automatic timer and they’ll do just that. Plus, if you’ve got an Amazon Alexa smart speaker, you can sync them up and use voice commands. How’s that for hands-free?
- Smart plug - control home electricals from your phone
- Turn devices on and off, no matter where you are
- Ready-to-use via Bluetooth - no hub required
- Use the Philips Hue app to control devices on-the-go
- Works with Alexa and Google Assistant
