From elevating the kitchen worktops to making the kid’s room more magical, this Philips smart LED strip will transform any space. There’re 16 million shades to choose from, so you can enjoy a warm white while you’re cooking or brighten up bedtime stories with deep hues of blue, pink and purple. It’s controlled from the app on your phone, letting you switch colours in seconds, and when the little ones need help settling down, the light can be dimmed as well. Busy day tomorrow? Give the family a hand waking up with the timer that turns the light on automatically. And thanks to the 25,000-hour lifespan, you won’t have to think about replacing the strip any time soon either.
Please note, to use the Philips Hue light bulb you’ll need a Philips Bridge (included). You’ll also need to download the free Philips Hue app, which is compatible with all iOS and Android devices.
- Smart lightstrip can be wirelessly controlled
- White and coloured bulb – choose from 16 million shades
- Standalone light with a 25,000 hour lifespan
- Schedule a timer to turn lights on automatically
- Dim the brightness to match your mood
