This extension is compatible with V4 Base only.
Extendible up to 10 metres
Extend your Philips Hue Lightstrip Plus by up to 10 metres by adding 1-metre extensions to cover larger surfaces and enable wider applications. From bright cove lighting to ambient navigation light in your hallway or stairs, anything is possible. Philips Hue lightstrip plus gives you full colour consistency from the first to the last extension.
Create the cosiest spot
Place a lightstrip where you like to relax most. Dim it down low, set to warm colours, and make your space comfortable, cosy, and completely your own.
Get the perfect atmosphere
From fancy get-togethers to family game nights, whatever occasion can be dressed up with the right colourful light.
Complement decor with light
Lightstrips can be tucked behind cabinets or underneath shelves to give any space an interesting, colourful, and ever-changing design element.
Control your way
Use the Hue app, your voice, or smart accessories to control your setup.
Customise with the Hue app
Set up and customise right in the Hue app! Easily change the colour, create automations, and more to make your lightstrip work for your space and the occasion.
Add accessories
Get a little more convenience out of your lightstrip with easy-to-use accessories such as a dimmer switch or motion sensor.
Go hands-free with voice
Pair with smart home assistants such as Amazon Alexa, Apple Home, and Google Assistant, to control your lightstrip with your voice.
Bright, powerful light
Get consistent colour — and with millions of them, it's really any colour — and bright, beautiful light.
Optimal design, optimal effect
The transparent sleeve was designed to keep dust and damage away from your lightstrip, meaning the light output is always at the optimal level.
Ultimate flexibility
Cut the lightstrip on the marked lines to fit your space, or make it even longer with extension strips up to 10 m. Bend, curve, and shape it to fit your space.
