Featuring a unique aluminum design, the Being ceiling light installs flat against your ceiling to provide a seamless apperance. Connect it to the Hue Bridge and control it your way.
Use over 50,000 shades of warm to cool white light to put you in the mood to work, play, or relax - no matter what time of day it is. Start your morning off on the right foot with cool, energizing bright white light, or settle down for the night with golden tones.
Smart lighting for daily tasks
Make your day easier with four preset light scenes that have been handcrafted for your daily tasks. Two cool-toned scenes, Energize and Concentrate, help you get going in the morning and keep your focus, while the warmer scenes of Read and Relax help you enjoy a good book and a rested mind.
Control lights away from home
The Hue app gives you complete control over your lights, even if you're not home. Switch your lights off and on remotely using just the app to ensure your home is always lit the way you want it.
Wake up and sleep
Set your lights to slowly brighten in the morning at a preset time to mimic sunrise and help you start your day feeling calm and refreshed. In the evening, the relaxing warm white lights will help you unwind, relax and prepare your body for a good night's sleep.
Control with your voice
When connected to the Hue Bridge, you can pair your lights with Alexa, Apple HomeKit, and the Google Assistant and control your lights using just your voice. Simple voice commands let you turn your lights on and off, dim or brighten your lights, and even set a light scene.
Connect to the Hue Bridge
This product requires a connection to the Hue Bridge to unlock the full smart control and features. Control your lights using the Philips Hue app, set timers, routines, add or remove lights and more.
Philips Hue White ambiance Being - ceiling lamp - LED - 22.5 W - warm to cool white light - 2200-6500 K - white
Ceiling lamp
Recommended For
Kitchen
Light Source Type
LED
Style
Contemporary
Dimmer
White
Wattage
22.5 W
Wattage Equivalent
204 W
Energy Efficiency Class
F
Colour of Illumination
Warm to cool white light
Colour Temperature
2200-6500 K
Luminous Power
2500 lumens
Intelligent Assistant
Google Assistant, Alexa
Platform
Hue, Nest, Echo
Communications Technology
Bluetooth, Zigbee
24 V
Frequency Required
50 - 60 Hz
Ceiling lamp
Recommended For
Kitchen
Style
Contemporary
Dimmer
Protection class I, remote controlled, ZigBee Light Link, diffused light effect, controlled via Bluetooth, app-controlled, 4 lighting programmes, voice control
