Fill your entire outdoor space with smart light using this outdoor power supply, which allows you to add up to 100 W of different lights. Connect two cables - each measuring up to 30 meters - to any low-voltage outdoor Philips Hue light on each connector, adding each fixture's wattage to reach the maximum 100 W threshold of the power supply.
Brighten up dark paths, create highlights in your landscaping or create a unique ambience on the patio. You can do it yourself, using Hue spots or bollards. The products are based on low voltage, safe to use and easy to install. No more complexity to get lighting outdoors: start to create and extend to suit your needs.
