This Philips USB monitor is ideal for usage in mobile clinical environment where AC power may not be conveniently accessible. Simply connect it with a single USB cable from your notebook to deliver video and power.
Germs have become a growing problem in hospitals and clinical environments worldwide as they can cause life-threatening infections. Philips clinical review displays take care of this challenge by using JIS Z2801 compliant antimicrobial additive in its housing material making it an integral part of the display housing. Your well being along with your patients is now assured by this protective shield that impedes the growth of most common microorganisms such as "Staphylococcus aureus (Gastroenteritis)", "Escherichia coli (E Coli)" and "Klebsiella (Pneumonia)", for example.
Medical grade power supply
Basic safety, essential performance and reliability are essential requirements in a professional clinical environment. Unlike standard displays, Philips clinical review displays employ special medical grade power supplies in order to meet these requirements. It complies with EN/IEC 60601-1 standard ensuring basic safety and essential performance. Additionally it also complies with EN/IEC 60601-1-2 collateral standard for medical grade electromagnetic tests and compatibility. Many countries, hospitals and clinics mandate compliance to these standards as a requirement.
LED technology
White LED's are solid state devices which light up to full, consistent brightness faster saving startup time. LED's are free from mercury content which allows for eco-friendly recycling and disposal process. LED's allow for better dimming control of LCD backlight, resulting in super high contrast ratio. It also gives superior color reproduction thanks to consistent brightness across the screen.
USB Power, Video
Philips USB monitor is capable of displaying images and drawing power directly from your laptop USB ports with a single USB cable. No extra power or video cables are required resulting in a simple, single cable, extra low power connection between your laptop and monitor.
70mm height adjustment
The Compact Ergo Base is a 'people friendly' Philips monitor base that tilts, swivels and is height adjustable so each user can position the monitor for maximum viewing comfort and efficiency.
Screen tilt and swivel
Screen tilt and swivel is a mechanism built into the base permits the monitor to swivel and tilt backward or forward.
Philips C221S3UCW - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
150 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
USB
Display Position Adjustments
Height, swivel, tilt
Voltage
Textured white
50.7 cm x 20.1 cm x 40.2 cm
3.85 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, RoHS, Lead-Free, WEEE, EN 60601-1-2, EN 60601-1
3-year warranty
Display Type
Diagonal Size
21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
150 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms
Horizontal Viewing Angle
160
Vertical Viewing Angle
150
Backlight Technology
WLED
OSD Languages
Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish
sRGB colour management, Smart Ergo base
Textured white
50.7 cm x 20.1 cm x 40.2 cm - with stand
3.85 kg
USB 2.0
Mechanical
Tilt Angle
-5/+20
Swivel Angle
130
Height Adjustment
70 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), antibacterial
MTBF
30,000 hour(s)
Power Supply
Internal
Input Voltage
Power Consumption (Typical)
10.3 Watt
Power Consumption Stand by
0.3 Watt
Apple MacOS X, Microsoft Windows 7, Microsoft Windows Vista, Windows 8
Dimensions & Weight Details
With stand - width: 50.7 cm - depth: 20.1 cm - height: 40.2 cm - weight: 3.85 kg , Without stand - width: 50.7 cm - depth: 5.9 cm - height: 32.3 cm - weight: 3.44 kg
